Am I running too lean!??
Here is the Air Fuel Ratio I got from the dyno I did the other day. I've been reading around about AFR and just wanna know if I am running too lean...
http://putfile.com/pic.php?pic=4/11818554625.jpg&s=x402
Re: Am I running too lean!??
Well first off where was the wideband located in your exhaust? Your a bit lean but you may want to have a bung welded in closer to your manifolds (beginning of Y-Pipe) to get the most accurate reading....
That doesn't look to bad at all. anything over 13.30 is a bit higher than ideal but I don't start to cringe until I see 13.40's across the board. You will likely loose a touch of power by going any richer.
Thanks for the input Alvin. I soon will be swapping out my Granatelli MAF for a stock MAF. I wonder how this will affect my car with the tune on it and all...
10-31-2016 11:09 AM
