another 383
#17
What setups have you seen or heard about that were disappointing?
I'm going to rev mine a little past peak power at the strip, which I'm guessing might be around 6200-6300 rpm. I trust my bottom end and valvetrain to just under 7000 rpms.
#18
i dd my 383 w/ and le1 350ci cam, passes smog so easily, and has gobs of torque, but im looking to upgrade to a bigger cam, and i highly suggest you do the same to get the full potential of your motor.
#19
Even though the xfi cam I recommended has .576 lift and the heads don't flow anymore air from .550 to .600 lift, the added lift means the valve is coming off the seat faster, so the cylinder starts filling earlier, that combined with good mid lift flow numbers could mean more midrange torque.
