Another MSD Digital-6 ?, what to do with extra wiring???
Well, those of you with the digital 6 ignition system know that there is some extra wiring just sticking out of the D6 system...I don't have Nitrous yet, but I will eventually and there is a magnetic pickup line that just hangs loose and a blue and a red line that also do nothing...the other 4 go to the MSD harness that I bought for it, but what did you do with the rest of it???
Any ideas on what it is for??? I saw some schematics in the instructions where they wired in a nitrous switch and a line lock solenoid to it, but I can't tell if that is what they are for.
I know there is the magnetic pickup which isn't used, but I'm talking about the red and blue wires.
Also, has anybody fit the Digital-6 right next to their cold air intake??? I have seen the 6AL mounted there and am wondering if the Digital 6 is bigger or smaller than the 6AL???
I have mine located behind the driver's headlight assembly on the horizontal area. I get cold air coming from the ducting by my headlights. I have the oem SS intake so I have room at that spot. I just tucked the extra wiring down into that cavity in the body below the driver's head light and above that black paneling you see from the bottom of the car looking up. If you cut the wires, you may regret it later if you need them or try to sell the unit later.
10-31-2016 11:09 AM
stockssn2o
05-25-2015 08:54 AM
