antifreeze over flowing? not overheating
my car was running with the temp on the first quarter like normal all day. then it went between there and half but never all the way on half between highway and street driving which i thought was normal. I parked in my driveway and when i came back out to my car the overflow had leaked all over my driveway i looked under the car and it wasnt dripping anywhere else. and ideas? i havent added any antifreeze for awhile so i dont have a clue
Re: antifreeze over flowing? not overheating
99% sure its a bad radiator cap. if it can't hold the 18lbs of pressure of the coolant system it will let coolant into the resevoir...spilling it over.
had it happen to my 96 and i've known several guys who have had the same problem.
when you replace it, make sure it is the proper cap...18lbs is more than most systems i think.
I continue to have the same problem with my car. Radiator cap didn't fix it. If my temp ever goes over 200, i can expect a collant dump. I think i more than likely have a blown head gasket...
Andrew
Andrew
well my cars been running pretty good. and i JUST had the engine rebuilt (only 1300 miles on it thus far) they replaced the radiator cap but they could have put a wrong one on. ill go get an 18lb one.
