Any advantages to oil temp gauge
Hey all,
I wondered what is gained by knowing oil temp information on a road racing car? I am able to put it in for some effort but don't want to make it a priority unless someone can give me a very good reason. It would be digital just like my oil pressure and water temp and would be adjustable to flash if above a certain temp.
Ben
Ben
For one thing, it can tell you if you need an oil cooler or not. Non-synthetics shouldn't go over about 240 deg. F. A sudden spike in oil temperature can also alert you to the fact that you are low on oil before pressure is ever an issue.
Magenta_Hearts
03-29-2017 08:54 PM
