Any FAST 93's in here?
I just found out that my transmission shifts at a weak 5500 rpm's so I wouldn't be able to take full advantage of a cam like the Hotcam that makes power all the way to 6200 rpm's. Changing the shift points in the 700R4 is a complicated trial and error process. So I was wondering if there are any 93 LT1's in the 11's (while still using the 700R4) and how did you guys get there?
Re: Any FAST 93's in here?
You are correct about the trial and error part.
Mine shifts now at about 6200. Took some time but came out nicely.
Just shift it manually at the track.
My car has a
custom grind cam
AFR heads
9 inch
3200 Vigilante
This that and a bunch of other stuff
On my 5th 700R4
My car has a
custom grind cam
AFR heads
9 inch
3200 Vigilante
On my 5th 700R4
That DFI will be very nice compared to the cave man ecm on our 93's
I had a nice ATI on my car for a short time and took it off. I had some nice pics of the front mount and so fourth but they are long gone.
My car has seen about 5 setups over th years. Likely just going to stick with H/C for all practical purposes of a street car more so than a drag car anymore.
