Any gasket sealant on intake/WP/timing cover gaskets?
I am replacing the top half of my motor and was wondering if you guys used anything like Copper gasket sealer on either the intake gaskets, waterpump gaskets, timing chain cover or oil pan gaskets......
Intake gaskets - dry, silicone on front and rear rails, permatex # 2 on bolt threads. Timing cover - permatex # 2. Waterpump - permatex # 2 on gasket surface and bolt threads. Oil pan - dry except for silicone bead at front timing cover and engine block junction, rear where pan rail meets rear oil seal housing.
