Any links to Pacesetter LT install guides?
Re: Any links to Pacesetter LT install guides?
I'm sure the directions between the two will be very similar. Also, the directions for the Pacesetter headers were subpar to say the least. They are vague and printed on a single sheet of paper. When I did my header install, I dug up a couple of tutorials from here.
ANY install guide will do....if anything, you will run across LESS problems (most likely) than any mentioned in any installs you find for other headers (I can't think of any examples). I would suggest finding 2-4 install guides with pictures - that way if something isn't clear as one you can refer to the other.
Originally Posted by Taintedz28
brents site has a write up for it I think
sc93
07-26-2002 02:02 PM
