Any power loss with the intake oil leak?
I may have the intake leak at the rear so i'm going to pop it off and fix it. I'm wondering though, any power loss associated with an intake leak?
Re: Any power loss with the intake oil leak?
Very possible yes, if the leak is allowing oil and unmeasured air to enter one or more intake ports that will hurt power. If the leak is just oil down the outside of the motor then no that would not hurt power.
IF the oil gets into anything it can hurt yes... Other wise not really...
I did the intake oil leak fix ... but seems I made it worse when I didn't get the intake one right... oh welll fudget... LT-1 heads and intake can blow me.... LT-4 here we come
My leak was responsible for some of hesitation. Power loss wasn't noticeable, but MPG went down a little bit. It's worth doing it by yourself, here you have some info and pictures to help you.
Originally Posted by CamaroZBoy
possible for a slight power loss....but besides that...dude...ur gonna have oil under ur carriage....rip off the intake and patch it up
cory
cory
Under my carriage? Dude, I have oil all the way down the passenger side floorboard almost to the rearend. Yeah, something's leaking
Cory
Originally Posted by kevm14
It sure as hell will if oil drips onto a wire or two, or the opti. The wires will swell and leak current to ground before it gets to the plug. Happened to my car and the previous owner.
Mine leaked from the front and back.Ya it got pretty messy. It leaked much worse from the back and very little in the front. I also had a bit of an internal leak. Now its all fixed and my car runs awesome. ONce its all off clean your intake and tb as much as you can. CLEAN IT ALL!!!. It will make a noticable difference.
