any thoughts on this manifold
I was planning on getting this manifold in the link(the top one)
The new setup it will be going onto is in sig.
I was just wondering if I am going in a good direction for a singleplane intake
http://www.edelbrock.com/automotive_...ds_chevy.shtml
and I was going to use the fuel rails in the bottom of the link
Re: any thoughts on this manifold
Originally Posted by Dave89IROC
it will work, you will need to either drill and tap new holes in the heads, or drikll the intake(some of the LT1 intake holes are in different locations)
thanks for all the help everyone
There are VERY few people who have switched to a single plane intake, so there aren't many people wo can help you. You might want to try a "search" on "single plane", since this topic has been discussed in a few threads, including on Advanced Tech.
Originally Posted by Injuneer
Sarcasm is always a good way to get help.
It just seems with this site if you ask a very basic question like what headers should I use or what cai 20 people will answer your post and if you ask a question like mine nobody reponds.
sorry if you took me the wrong way I was just upset nobody reponded to my question and I didnt mean to come across as an a$$hole
Like mentioned above, some bolt holes will have to be drilled and tapped in the heads or the manifold should be drilled. Also, this intake is lower, hence has less volume than the super victor. Other than that it will work.
I already have and I didnt find much info at all.
