Any word on the Delteq Stage 2?
Old 09-06-2004, 09:29 PM
GhostZ's Avatar
I know a few months back they were delaying the release of the Stage II to work on some problems and it was supposed to hit the shelves shortly thereafter.
Searched but can't find anything on the anticipated release of the Stage II.
Anybody.....Maldo?
TIA
GhostZ is offline
Old 09-06-2004, 10:04 PM
ledfootz28's Avatar
Re: Any word on the Delteq Stage 2?
dunno but im interested too.i didnt know they already scheduled a release then cancled.stage 2 is the system thats going to delete the opti completly right?
ledfootz28 is offline
Old 09-06-2004, 11:08 PM
GhostZ's Avatar
That's the one.....apparently there were a few things that needed working out so it was delayed but I thought the Stage II was supposed to be out by now. Haven't seen anything on Delteq's or Maldo's site. I was going to get the Stage I but seeing as it's so late in the season, I'll probably just hold out for the Stage II.
GhostZ is offline
Old 09-07-2004, 12:59 AM
ZeeDub's Avatar
wtf is a stage 2? LOL
ZeeDub is offline
Old 09-07-2004, 01:33 AM
Bryan Smith's Avatar
Its faster yo.. adds mucho hp. Comes with 22mm wires dooD!
In all seriousness, stage 2 is just the second version of the delteq system right? Fixing a few bugs in teh optibox?
Bryan Smith is offline
Old 09-07-2004, 02:52 AM
GhostZ's Avatar
Stage 2 eliminates the opti completely whereas the Stage 1 is still using the optics from the opti.
GhostZ is offline
Old 09-09-2004, 03:28 PM
Birdman7389's Avatar
if no one is having problems with the optical part of the opti, why bother to replace it?
Birdman7389 is offline
Old 09-09-2004, 03:58 PM
unvc92camarors's Avatar
same question here
i'm curious as to why stage 2 is needed (or preferred) since the optical part of the opti is fine
unvc92camarors is offline
Old 09-09-2004, 04:09 PM
WS Sick's Avatar
That way youcan do away with the opti eyesore. Also allow you a more universal camshaft position sensor, much smaller.
WS Sick is offline
Old 09-09-2004, 09:03 PM
1Qwik94Z's Avatar
Red face Re: Any word on the Delteq Stage 2?
WTF are you guys on drugs or something?? Why on earth would you want to DELETE any part of the Optical Spark Distributor system? Its only the best thing GM has designed since the wheel..(or was that FORD? )...Ive only had three problems in three months with mine!
1Qwik94Z is offline
Old 09-11-2004, 01:36 AM
texanmutt's Avatar
There are alot of reasons to replace the opti-
1) Cap and rotor failure (eliminated when you have coil packs)
2) Hi res slot blinding from corosion
3) Bearing failure due to a small, cheap bearing
4) optical sensor failure (very rare)
texanmutt is offline
Old 09-11-2004, 01:38 AM
chy20k1's Avatar
i have the delteq stage 1 now, i will be the first in line to buy the stage 2 when it comes out.
chy20k1 is offline
Old 09-11-2004, 08:40 AM
TenaciousZ's Avatar
Actually, there is a tech guide in the new CHP for the delteq. I'm pretty sure it's the stage 2 since your deleting the opti completely. I think i'm in love with it.
TenaciousZ is offline
Old 09-11-2004, 09:42 AM
No, it is not the Stage 2 in Chevy High Performance. From the bottom of page 64:
The Opti-Direct system uses an electronic interface module, otherwise known as the Opti-Box. So, rather than relying on the cap and rotor to distribute the spark, the Opti-Box receives the signals directly from the Opti-Spark sensors and then sends the signals to drive the multi-coil system.
A couple of us have been running the Opti optical sensor alone, to drive aftermarket ECU's and 8-channel igintion systems since 1998 with no Opti-Spark failures.
Injuneer is offline
Old 09-11-2004, 09:43 AM
TenaciousZ's Avatar
My bad, I must have missed that part.
Quick Reply: Any word on the Delteq Stage 2?
