Anyone else broken an Oil Pressure Sending Unit??
This little things are really POS's for where they're mounted. You gotta be careful. I was poking around under the car, and let fly with my arm after the wrench slipped off my O2, and snap, there goes my second.
Why hasn't someone made a completely integral metal unit that won't snap off at the base. They're cheap and all at $30 a pop, but there's room for improvement.
Originally posted by Grease
I did the !Oil pressure mod when I had the tranny out The engine leans back and its up to the sending unit to hold it against the firewall. The don't hold lateral pressure that well. LOL
Yeah I btoke mine while changing #7 plug,and talking to my nieghbor(wasn't paying attention).Got a new on e from Dal,shipped in 3 days ,put the new one on,had high reading but after a week,it settled back to normal.($26.00 about 3 years ago).I couldn't believe I did that,der.
i broke mine when i took the y pipe out to gut the cat. then replaced it but but for some reason my oil pressure was never the same. then when tearing my engine apart for the rebuild i found the culprit of my low pressure problem........ my pick up was not attatched to my oil pump
:redneck: that there aint no kinda good :redneck:
but it will be fixed with the 383 so its all good
