Is anyone else's gas Gauge off ?
Old 08-11-2003, 02:03 PM
  #16
FireAm94's Avatar
It's not that bad....you can either cut a hole above the tank or just drop the rearend.
Joe
FireAm94 is offline
Old 08-11-2003, 02:05 PM
  #17
drewstealth's Avatar
yeah mine does the same. Goes past the full, then to the 3/4 it goes pretty slow after that it goes pretty fast. But i can let it get to E without running out of gas even though i usually fill it up at about 1/4 tank. Except one time i was at E and i filled the car up and it only let me put in a little over 6 gallons of gas. It wouldn't let me put in more. Then i started the car and it said i only had 3/4 a tank. It was weird. But it hasn't happened since.
drewstealth is offline
Old 08-11-2003, 02:06 PM
  #18
AxeGrinder30thZ's Avatar
I just always make sure I fill up before I get near E. I don't think LS1's are much different, because my buddie's '98 does the same thing...if not worse than my '97.
AxeGrinder30thZ is offline
Old 08-11-2003, 02:10 PM
  #19
Lyle A's Avatar
Mine is off as well as everyone elses. I never let mine get past 1/2, which is more like 3/4 empty. Better safe than sorry.
Lyle A is offline
Old 08-11-2003, 02:11 PM
  #20
TobyZ28's Avatar
When I first bought my Z a few years ago the previous owner said that theres still a quarter tank of gas left. I was like cool...
FIrst thing i did was try and calculate my milage based on that quarter tank. I basically **** myself when after driving it only a little bit that day, when the guage just DROPPED down to the E. I, not knowing anything bout cars whatsoever, thought i was in serious gas trouble as this was gona be my main commuter to work. Thank GOD it wasnt as bad as i thought it would be
TobyZ28 is offline
Old 08-11-2003, 04:18 PM
  #21
gd1996ss's Avatar
Turns out my guage is off, way off! It was reading an 1/8 of a tank, not that close to E, and it was empty. I thought I had a bad opti, but guess not. 3 gallons of gas, froma can, now reads a half of a tank... this is a 93, so maybe the problem was way worse back then. So know I know when its at a 1/4 Its time to fill it up!
gd1996ss is offline
Old 08-11-2003, 04:28 PM
  #22
RCF925's Avatar
Quick fix for gauge, I took my instrument panel cover off, Moved the needle 1/4 tank to the left. Now when I fill up its on the F
RCF925 is offline
Old 08-11-2003, 04:35 PM
  #23
neil350's Avatar
I only go to about a little more than 1/4 tank which is about 12 gallons on my car, so fuel is in it and I dont burn the fuel pump out.
neil350 is offline
Old 08-12-2003, 12:18 AM
  #24
Van5150's Avatar
Is that true RCF925 ? You just moved your needle?
Van5150 is offline
Old 08-12-2003, 01:18 AM
  #25
MentalCaseOne's Avatar
GOD DANG!!!!! Dude you have one Big AZZ tank!!
!2gallons and its only 1/4 thank?? I would hate to pay to fill up your thank!!
Not .. really I know you meant to say.. 12 gallons to fill it up from 1/4 full.... right??? please say yes....
Marvin
MentalCaseOne is offline
Old 08-12-2003, 03:39 AM
  #26
Jcb890's Avatar
i have the same reply as most others. when i fill it all the way it goes past Full, but i can run it down to E and run it on E for a little w/ out running out of gas. ive noticed w/ the car off and in neutral / at idle it is the most accurate. ive also noticed these few things: while accelerating the gauge goes up, gauge goes down while braking, gauge goes up while turning left, and gauge goes down while turning right. to b honest w/ u, it dusnt really bother me, if i didnt have a gauge id still hardly ever run out because i know how many miles i usually get out of each tank, i think thats something every1 should know, because what happens if ur gas gauge stops working??? then u wud b f*cked.
Jake
Jcb890 is offline
NUR2S
05-29-2015 03:52 PM
zxtce
05-07-2015 08:53 PM
warmeck
03-22-2015 06:43 PM
99TransAmWS6
02-12-2015 07:23 PM
blac94Z
11-24-2014 07:12 PM
Quick Reply: Is anyone else's gas Gauge off ?
