Anyone have info. on the Mcleod Adjustable Clutch Master Cylinder?
Am thinking if I need to get this on my car. I currently have the spec stage III on for almost a year now and it is acting a little funny. The engage point is practicaly right when I take my foot of the clutch which it has never been that bad before. Also when I am in fourth gear and when I smash the gas down it feels as if the back tires are giving out but it is more of a vibration and no speed increas just rpm.
you dont need the master, you need a new clutch.
sounds like the clutch is going out, if when you give it gas in 4th and RPM's go up but you dont go faster..the clutch is slipping.
sounds like a typical SPEC...mine only lasted a year.
I thought for a clutch to be slipping it usually starts in 6th gear and as it gets worse it goes down the gears. Also it still hooks up when in first and second and so on. I am only running around 320 the the rear. Also when I bought it they said this clutch should last the life of the clutch. Thinking about calling S.P.E.C. and bitching them out to see if they can do something about it.
carguyshu
01-22-2017 11:19 AM
