Anyone know HP or 1/4 Mile Time??
#16
Quit all your bickering. His car has 2.73s stock. 93's were available with 2.73's or 3.23's. 94 I believe is when they changed over to 3.42's stock on all M6 cars.
And the TB bypass has been dynoed tested for around 4-8rwhp. Think about it... cooler air is denser = more hp.
#17
#19
if you want to say the TB bypass doesn't "gain" horsepower, it keeps you from loosing horsepower.....then you could also say that headers don't "gain" horsepower, they free-up horsepower, same with a cat-back system.
and i serisouly doubt he's going to be running his car down the 1/4 mile while the engine isn't up to temp.....so the TB bypass would infact be in effect.
#20
Headers help you regardless if the engine is cold or hot. The same is true of almost any mod. That is why I differentiate the TB bypass from other mods, because it does not always make an improvement in HP.
I agree that if your car is warm at the track, it is better to have the TB bypass.
Dan
#21
Most or all 93's came with the ZF 6 speed from the vette and as for the gears I'll have to check, I have one of the original shop and sales manuals they gave the mechanics in 93 to introduce them to the new style. I'll check it when I find it.
#22
Year Model/Optn 1st 2nd 3rd 4th 5th 6th Final
1993 Manual/M28 3.36 2.07 1.35 1.00 0.80 0.62 2.73 (GU2)
1993 Manual/M29 2.97 2.07 1.43 1.00 0.80 0.62 3.23 (GU4)
#27
I don't think I'd put 4.10's on that tranny. Look at 1st gear. You would zip through first before you knew it, and I bet you would have a VERY HARD time getting any traction in 1st.
I would go 3.73 max.
Dan
Dan
