Anyone seen worse than this?
Old 03-30-2008, 06:02 PM
Ekof96Z28's Avatar
Whatcha guys think...
Stock 158k miles 95 Z28
Runs great, burns a bit of oil, pressure is very low on idle, but otherwise almost where it needs to be.
Ekof96Z28 is offline
Old 03-30-2008, 06:10 PM
97s10ondubs's Avatar
OMG, that is all!
97s10ondubs is offline
Old 03-30-2008, 06:15 PM
PWR SHFT's Avatar
It runs?!?!
PWR SHFT is offline
Old 03-30-2008, 06:30 PM
MeanGreen97Z's Avatar
I'd say someone didn't change the oil often or there was a leak! Either way you take the prize on the most baked motor I have seen.
MeanGreen97Z is offline
Old 03-30-2008, 06:32 PM
2000GTP's Avatar
Let the cleaning begin.
2000GTP is offline
8cylinders>4's Avatar
holy f--kstick!!
what kind of oil did you use? did you ever change it? how many miles have you had the car?
that is the absolute most god awful sight i have ever seen inside an engine
8cylinders>4 is offline
Old 03-30-2008, 06:35 PM
kylersaulsbury's Avatar
DAAAAAMN!!
The only other moter that I've seen that was worse was in my engine rebuilding class at school. But his didn't run. Or turn over cuz the bottom was even worse, you couldnt even get anything to drain out.
kylersaulsbury is offline
Old 03-30-2008, 06:53 PM
maybe2fast's Avatar
this is my valley after 100,000 and the new heads just bolted on.
maybe2fast is offline
Old 03-30-2008, 07:00 PM
Ekof96Z28's Avatar
I just picked the car up.
We flushed it when we did that so hopefully it is a bit better now....
Lost alot of oil pressure after the flush though... so I need to decide to either rebuild, or pull the pan, change the pump and hope for the best.
Old 03-30-2008, 07:04 PM
dangalla's Avatar
when you flushed it where do you think all of that went? there is a good chance it is in the pan clogging the oil pick-up. at the minimum you need to pull the pan and clean the pan and pick-up. but with the motor looking like that i would just build the motor
dangalla is offline
2000GTP's Avatar
When I used to work as an auto tech, I saw this happen several times on higher mileage engine and trannies that had neglected maintenance. It seems like the sludge kind of holds things together, once you flush the crap out, the problems really begin.
2000GTP is offline
Old 03-30-2008, 07:07 PM
maverickmk's Avatar
HO-LY CRAP! you need to rebuild that - if I had a machine shop I'd charge extra to clean that crap
maverickmk is offline
Old 03-30-2008, 07:11 PM
Ekof96Z28's Avatar
Yeah, I have a feeling it is going to cause many many problems.
My buddy wants me to yank the pan, swap pumps and pray.... but i'm thinking it wouldnt be worth the money with this many miles on the bottem end and the sludge that is in there.
Old 03-30-2008, 07:13 PM
dangalla's Avatar
no i dont think its worth it either, but FYI the pump is prolly not the problem its the pick-up
dangalla is offline
Old 03-30-2008, 07:14 PM
maverickmk's Avatar
in my opinion: best case scenario is runs but probably not very well
worst case you throw a rod and then you're looking at a larger cost to fix
Quick Reply: Anyone seen worse than this?
