anyone using this radiator setup?
I swapped an LT1 into an '89 Camaro RS.
I went with the '89 IROC radiator (plastic/alum) because it bolted in so cleanly. Now I need to find a lower radiator hose. The stock LT1 upper hose worked fine, but the lower one is too small (diameter) to fit over the lower radiator outlet.
Anyone ever done this? If so, do you have a part nbr or remember the application? I just spent an hour at AutoZone trying to match one and no luck.
Thirdgen.org will help you on this one
http://www.thirdgen.org/techboard/en...ight=lt1+hoses
http://www.thirdgen.org/techboard/ltx-lsx/
detroitmuscle
07-31-2015 04:21 AM
Noct
07-14-2015 01:18 AM
ducttape1975
07-10-2015 06:29 PM
