Anyone want to suggest some lifters?
Neeed some lifters, the stock ones seem to routinely grenade on me after a few thousand miles, the cam is slightly smaller than a 306 on a 114 LSA with 1.6 rockers
Comp Cams makes two sets that I know of for a roller motor. The stock replacement set and the Comp Cams "R" series for higher lift cams such as the 306. Summit sells both. They run between 169.00-200.00 dollars. I run the stock replacements with the Comp Cams XE 230/236 with .650 lift springs and 1.6 rockers on AFR heads and have had no problems.
HVY SS
HVY SS
