ARP to a TCI flywhell.
Okay well i bought a TCI fly wheel. Then choose to go with the ARP flywheel bolts. Now it seems that the bolts are to long. I can shake the flywheel. Is it suppose to be like this are do i need special bolts now that i have a non stock fly wheel. Any help is welcomed. Thanks
Re: ARP to a TCI flywhell.
flywheel or flexplate??? I can't find a TCI flywheel listed, in a 2 minute search.
I suspect you are calling a flexplate a flywheel and in doing so you bought the wrong parts. A manual tranny setup has a flywheel, and automatic tranny setup gets a flexplate.
i am pretty sure it is correct. cause i go to the tci page and i can only order for automatic. Maybe i just need to shim it but not sure.
