!ASR Keep Cruise
#16
Are you sure you don't have the cruise module? Its behind the splash shield, you gotta pull the shield to see it, but there is a throttle cable routed to it and you can feel it with a finger stuck in the right hole. My 95 has ASR and Cruise, and it has the separate cruise module.
I had thought they were integrated, too. Nice info above. I am happy to know I can finally ditch the ASR stepper motor without losing cruise.
I think the cable P/N above is wrong? I could not find that number. I found:
Non-ASR Cruise Control cable 12550719 elsewhere, though.
Also, you will need an accelerator cable. Per Shoebox:
1994-1996 accelerator cable-no traction control 12550676 $11.12
1997 accelerator cable-no traction control 12554852 $11.93
Also this link for procedure: http://www.pharmacy.arizona.edu/staf...eadjuster.html The main page also says the computer needs to be changed to run only ABS, no ASR.
Anybody know if that is true? I'll search, but easy answer appreciated!
#17
Okay i looked again to make sure it dodnt have the module it doesnt but it appears all the wiring is there. Can Someone take pics of all of the electrical connections on the module to make sure I have the correct wiring? the color of the plugs would be helpful too.
Or does anyone have a picture of the module connection points where the electrical plugs in?
WobblySausage
10-07-2015 10:09 AM
