Autometer A/f gauge install
I put my Autometer A/F gauge in today and it works supposedly fine but I want your guys thoughts.
I installed it at the PCM using the purple wire (theres a Purp/White also but that for the other side)
I get the sweeping of the gauge during normal driving but when I hit the gas then it reads correctly. (Wide band o2's)
Now I was woundering if I installed it closer to the o2 sensor would I get a better reading and not have the light show or would ity just get worse?
I've read that it wouldnt be as accurate though.
I have the Ultra Lite gauge just so you know.
Re: Autometer A/f gauge install
In effect, the gauge is little more than a psychedlic light show.
Why do you think you have "wide band O2's"? You don't unless you are running an aftermarket engine management computer, with a pair of $350 sensors. And, an AutoMeter A/F gauge wouldn't work with those sensors, because wide-bands have a 0-5V signal range, and the AutoMeter is looking for a 0-1V signal from your stock, narrow-band sensors.
99TransAmWS6
02-12-2015 07:23 PM
