Bad day at track!
Bad day at track!
Hey guys,
I just ran between a 15.1 to a 15.3 at the track the other day. I usually in the past run low 14's to mid 13's. I have noticed since i modded my car times have actually became worse. I recently installed a vigallante converter and headers and still have problems with my track times. It seems like from my 1000 foot times on to the end of the quartermile seem to end kind flat. My thousand foot time now is about 12.7 and ending time is 15.1 to 15.3 at 91mph. compared to 11.7 at 13.4 at 100 mph. Any ideas why I would have such a discrepency????
Re: Bad day at track!
I recently put my stock mass airlfow sensor back on because I was running too rich. The hypertech did not lean my car out like it should had done. Now that I put the stock mass airflow back on it runs not so rich.
Since I put in the stock MAF, the car is not running rich anymore! I might just have to get the car tuned. Maybe the hypertech is just junk and my MAF just needs to be calibrated by a custom tune. I could try just taking off my hypertech programmer and then see how it runs.
My sixty foot time is now 2.30 which is not very good considering that i have a vigalante torque converter. I will take the hypertech off and then try it. I also might put my LT4 knock module back in to help the retarding. I think the lt4 module will only help
a stock lt-1 usually runs 2.0 to 2.1.... maybe 2.2 with a lot of miles on it.
With a larger stall (which incedently you haven't told us how big it is) you're 60' time should be lower unless you had awful launches.
Like I said before take off the aftermarket MAF and see what happens.
While you're at it. check for burnt plug wires. you might have misrouted one when you put the headers on
