bad maf, pcm, or grounds
#16
#17
#18
You, on the other hand, have contributed a lot. A lot of false information.
Which makes this guy an idiot:
And this guy also:
So, does it or doesn't it go into "limp home mode"?
If it does, then please show us where in the manual it describes how it goes into limp home mode when DTC 48 is set. Surely it's documented in the manual. Or is it a secret that only you know?
#19
But your fuel economy is going to suck and it ain't gonna run right, especially if you have changed ANYTHING on the induction or exhaust. If your airfilter is clogged up and needs to be changed its going to run ****ty if your MAF is descreened, its going to run ****ty. The SD tune is for a stock engine with full emissions equipment so if hes changed anything on the exhaust or intake its going to run ****ty, hell I wouldn't be surprised if using a fram paper filter instead of an AC Delco paper filter caused a minor change to the volumetric efficency of the engine.
My BLMs in SD mode with the stock tune are no farther off than my BLMs in MAF mode with the same stock tune.
#20
And this guy also:
And this guy also:
eanhl2004
04-04-2015 12:01 PM
07-04-2005 05:00 PM
