Bad MAF sensor on '95 Z28
Originally posted by shoebox
You can clean it at virtually no cost compared to $200. What steps did you take to determine it is "bad".
What symptoms is your car exhibiting? Other than the SES, does it have problems at certain RPM possibly seeming like its not kicking into gear right (which might really be the car throwing a bad Fuel-Air mix causing it to not combust properly producing a drop in power)...?
What code was set?
I had a recurring SES light that pointed to the MAF, and it ended up being a short in the pigtail connection leading up to the MAF. Threw on a new pigtail and was back in business code-free.
If you've got a friend that can hook you up with their MAF for 10 minutes, you be able to rule this possiblity in or out.
07-04-2005 05:00 PM
