Bad Night at Track
Bad Night at Track
Well barometric pressure was 30.08 and humidity was 98%. People there said they were running a solid .4-.6 tenths slower than usual and were trapping 3-4mph slower. I talked to about 10 different racers and that was the average. On my first run I broke the tires loose at 90mph! I ended up short shifting to 4th to regain traction. Regardless, I ran a best w/ dr's :
60' - 2.065
330 - 5.509
1/8 - 8.356
MPH - 87.72
1000 - 10.769
1/4 - 12.802
MPH - 111.32
Best 1/8th mph was 87.82 and best 1/4 mph was 111.52
I know there is definitely more in it with better conditions. Track sucked for traction. Anyone know what the corrected times would be based on the baro and humidity? Temp was around 60 degrees.
60' - 2.065
330 - 5.509
1/8 - 8.356
MPH - 87.72
1000 - 10.769
1/4 - 12.802
MPH - 111.32
Originally posted by Kain
What was the temp out too? Barometer was good, except that humidity was a killer!
The barometer and air temperature are actually favorable. Its only the relative humidity that cost you any performance... and humidity doesn't have a huge affect. If you reduced the humidity to 0%, you would pick up .5mph and about .06-seconds.
Use the CZ28.com online calculations directory to find the ET/MPH correction.
wytblur
08-05-2002 02:03 PM
jp2002ls1
07-22-2002 04:18 PM
