banks 1 and 2 lean condition
hey guys i put a cold air induction, ported maf and headers on my 96 z28 now i have a 171 and 174 code. how would i fix this problem? the car runs good but gets really hot under the hood.
also has a popping on decelleration. i have a adj. fuel reg. but its not installed yet. will that fix this or do i need a programer to change fuel mixture? any info would be great thanks.
scott
scott
When you port your MAF, it still thinks you have a certain amount of air going through that MAF sensor. More air is going through than it really thinks there is. When you add air and not more fuel then you get a lean condition. What you need to do now is program your MAF 1-4 table to compensate for the increase in MAF size.
Adjustable fuel regulator wont do anything for the issue. I dont have an OBD II car, but if those are O2 sensors lean (the only lean warning I know of), then its an exaust leak more likely than the MAF.
Henson071
08-04-2015 09:32 AM
zajones
07-30-2015 02:18 PM
Noct
07-14-2015 01:18 AM
