beehive valve springs
how many diff companies are sellin them i just bought a used set of heads to send out to loyd and they have beehive springs on them but no color band on it like mine on my car are blue down the lenght of it and these have none i cant post a pic cause i cant add attachments for some reason any help is appreciated
There are a few, but I think they all come from the same place, PRC. You can find info on them in the sponsor forum. I know PSI also has some besides CC, but I've also seen Lunati marketing them as well. You'll have to test them to figure out the specs.
The blue band doesn't mean much......
Don't worry about that, have the springs all removed and have the shop check them for pressure at 1.750" height. They should all be within 140-145lbs there, if so they are most likely good.
If you need a replacement set get a hold of Lloyd or I and we can get a new set out to you for a good price.
Bret
Bret
PRC doesn't make springs. PRC buys them from associated spring along with Patriot, manley, and comp.
Lunati, Ferrea, and Crane buy some from us along with our own brand.
You can not go by the stripe anymore. Some of ours get a stripe and some don't.
