Bent 2 rods in my LT1 Stroker..WHY
#16
Re: Bent 2 rods in my LT1 Stroker..WHY
In my research, when doing mine, it was 10* +0.050 locks and 10* retainers. I'm using PAC 1518 springs, but they should be the same style as the 918.
The part numbers I got were....
Spring Retainers 10* - CCA-795-16
Valve Locks 10* +0.050 - CCA-614-16
Spring Locator Kit(seats) - CCA-4705-16
The above hardware should net you a 1.75" install height(from my understanding...mine were just a hair shorter).
Here is one of the threads I got it from....
https://www.camaroz28.com/forums/sho...ocks+retainers
The hardware will depend on the type rockers you use SA or NSA(I'm using NSA). Wouldn't hurt for others more knowledgeable to chime in....if you have SA rockers, pay attention to Nightrain66's post in the above thread(post 21).
10-31-2016 11:09 AM
Hurin
12-13-2014 07:38 PM
