Best bang for the buck mods
Old 04-21-2009, 11:52 AM
  #16
6SpdLT1Z's Avatar
Originally Posted by RicksChevrolet
How do I identify if my car is a code GU2 or GU5?
Glovebox RPO code
6SpdLT1Z is offline
Old 04-21-2009, 12:31 PM
  #17
94SLUG's Avatar
Stall 3000 + by far the best mod on a stock A4!
94SLUG is offline
Old 04-21-2009, 12:59 PM
  #18
EnFuegoZ28's Avatar
I put a baby stall on my DD Z28. It helps alot. I went small so I wouldn't be driving around with it unlocked all the time. (I'm usually in the 2400-2500 range around town)
Next on the list is LT's, new catback, 1.6 rr's, and a tune.
EnFuegoZ28 is offline
Old 04-21-2009, 02:02 PM
  #19
The Captain's Avatar
Originally Posted by MikeGyver
Nitrous.
Im a little hesistant about putting nitrous on my daily driver. I dont race it either, so it would really be kind of pointless.
Im keeping an eye out for a set of used ceramic coated headers, either shorts or mids. Does anyone know if the 93s require a certain type of headers, I know some things are slightly different on them than the 94-97s.
Like I said earlier the roads are just too bad around here to have LTs and and not get them all banged up.
The Captain is offline
Old 04-21-2009, 02:36 PM
  #20
pattracing212's Avatar
i have a set of shorties on ebay right now that end in 2h:30 min off a 94. i went up to longtubes, and i'm in illinois too lol, southside of chicago
http://cgi.ebay.com/ebaymotors/1994-...Q5fAccessories
pattracing212 is offline
Old 04-21-2009, 02:49 PM
  #21
Super Moderator
JakeRobb's Avatar
Get stainless steel headers. They can still be ceramic coated if you like, but mild steel on a daily driver is a mistake whether it's coated or not.
Also, note that the more expensive headers (like Kooks) have equal-length primaries, which both sounds better and makes more power than cheap headers (like Pacesetters).
JakeRobb is offline
Old 04-22-2009, 02:49 PM
  #22
RicksChevrolet's Avatar
Where is the best place to get stainless headers? I tried to search for Kooks and nothing came up for my 95 LT1. Since I am going to replace my head gaskets soon I am planning on putting headers on it.
Would ideally like to get stainless equal length headers.
RicksChevrolet is offline
Old 04-22-2009, 05:07 PM
  #23
joeSS97's Avatar
^^^Rick,scroll up near the top and click on the supporting vendor index.Thunder racing I believe has them.Look around there.
joeSS97 is offline
Old 04-22-2009, 05:16 PM
  #24
CrashnBurn's Avatar
best bang for buck...Gears, Stall, Headers, Tune, and LS1 Lid conversion...look it up...i currently have k&n intake but in process of changing over. Don't forget your suspension though
CrashnBurn is offline
Old 04-22-2009, 05:49 PM
  #25
n2ceptor's Avatar
Glovebox RPO
GU2 = 2.73
GU5 = 3.23
GU6 = 3.42
n2ceptor is offline
Old 04-22-2009, 07:44 PM
  #26
So, I have the GU2. (probably why my car is a dog) I have to change the entire rear-end. What is the best to get? Which car is most likely to have it?
Old 04-22-2009, 08:07 PM
  #27
n2ceptor's Avatar
Hey Cap, this is what I did with my 93Z...
Scroll down to my name...
https://www.camaroz28.com/forums/sho...98#post5831098
n2ceptor is offline
Old 04-22-2009, 09:08 PM
  #28
Would on 01 S10 .373 rear end work?
Old 04-23-2009, 06:50 AM
  #29
Super Moderator
JakeRobb's Avatar
No, you can just change the gears inside it.
You'll most likely need to upgrade from your 2-series carrier to a 3-series carrier as well.
JakeRobb is offline
Old 04-23-2009, 11:33 AM
  #30
Tanner_94_Z28's Avatar
look in the glove box there will be a white stick read the code if u have GU2=2.73 and GU5=3.23 also if you car doesn't have the first gear in the automatic shifter also means that you don't have the performance rear end which is 2.73.
Tanner_94_Z28 is offline
Quick Reply: Best bang for the buck mods
