Best Motor Oil and oil filter??
#17
Re: Best Motor Oil and oil filter??
Originally Posted by nick13077
Hey guys,
I went with the Mobl 1 Oil and Filter. Now I need some new spark plugs and wires. Also what company makes a good Oil Pressure gauge system? Autometer? Also what are the best brands for all the other fluids (i.e -brake, transmission, rear-diff, etc). Sorry, I know that I am asking alot of questions, but just want to make sure I get the best products for the tune-up!
#18
CALL i have been wanting royal purple for awhile...i have heard that and redline are the best..... but my car has 93k miles but since the last change has been barely driven....driven but driven nice and just a mile or 2 a day....should i still go with royal purple???
#19
IMO Royal purple is the best. Now, at the same time, if you onle drive it easy a mile or two a day, I can't say that it would be in your best interest to switch to Royal Purple. My Formula in my Sig is my daily driver, and it just gets Valvoline durablend. Also, if you go with synthetic with anything more than 75k on your motor, you will probably encounter some leaks since the oil is synthetic and your seals aren't what they used to be.
#21
I see a lot of people recommending the Mobil 1 oil filter. I have used those a couple of times, but now I just refuse to pay $10-$11 for an oil filter.
I prefer Castrol GTX 10w30 for conventional oil, or Mobil 1 0w40 for synthetic, and an AC Delco filter (the taller one with more oil capacity I believe it's a full size truck filter).
#22
Royal Purple and Redline are marketing companies. They have another company make the oil for them. FWIW the motors I have torn down that have run that stuff look like *** compared to M1.
NEVER NEVER NEVER should you switch from Synthetic to Dino oil unless you want the motor to wear out faster. Just put M1 in there and if you need more oil pressure switch to a thicker oil. ie from 5W-30 to 10W-30.
Bret
Bret
#23
As previosly stated, Royal Purple and Mobil one are pretty much the best. Mobil one filters are pricey, but the way I see it, I would rather spend an extra $5 on a filter, than go with something that won't filter as well (Fram for example).
As for my money pit (383, 95 Z), lets just say I have more than just go fast parts on it. And as you can guess with my preference for the best(and probably most expensive) oil filter, money was not spared when buying the best parts available either. I have over $16,000 just in my motor alone. BTW, I am about ready to drop another $8,000 when I go to pick it up from the shop this week. (Just changed pistons, and custom cam, and had motor spec'd out and balanced with new seals ect. + D1SC, custom intercooler, ect, ect, blah blah blah.
#24
oil has been covered already, but ill throw my .02 in on the filter. I only use WIX in my car, and i use an oversized one. Pretty much the best filter you can buy for like 7 bucks.
#27
Bret
Bret
#28
#29
Originally Posted by 1LESSZ28
Bret, what is your opinion on going from dino to full synthetic? 68k miles
Do it!
Other than that if you have a big oil pan like a Canton I agree that the truck oil filters are the way to go.
Bret
#30
My choice is Mobil 1 5W-30 with a K&N Filter. I've used a variety of oil. Those two combinations have been my favorite. I'm interested in the new TruFilter Jeg's has advertised. It's really pricey. Not sure about that one. I'll just have to wait and see.
