Best Tune Up parts?
Best Tune Up parts?
Camaro z28 a4, CAI, Flowmasters, and fan switch
Its about time for my tune up, i just need to know am i missing anything or is there anything u suggest i add? and keep in mind it has 180XXXmiles
Clean K&N filter
Oil filter - heard alot about napa but where to buy?
fuel filter - acdel
spark plugs - ngk 55 ir.. u know the ones
wires - msd 8.5
and should i buy some maf spray? never been sprayed if so what brand and is there a special way to do it?
Clean K&N filter
fuel filter - acdel
wires - msd 8.5
I used MAF spray and I did notice a little bit more smoothness in my 110K engine. I'd do it.
also seafoam would be a good idea to do before you change your plugs, as apparently it sometimes can hurt your plugs. Also made my engine a slight bit smoother.
Well see my car is my DD and i really have no time to do the work myself and ture the cap and rotor is only 150 but im gonna be paying for labor buying all the parts to save high costs on BS, but now can u understand the mad faces
how many miles are on your water pump. If its a lot you might as well change that and while you are that far in, change the cap and rotor. If you dont and your water pump dumps on your opti youll be replacing the whole thing instead of just the cap/rotor.
you dont have to do every thing at once. One day do the paasanger side plugs and wires, another day do the other side and so on. Ifyou dont know how to do it just post in here. I could do all your talking about in under 2 hours.
You can do plugs and wires on an LT1 in 2 hours?!?!?!?! I wanna see that...
