Best wide band w/ data reporting?
Re: Best wide band w/ data reporting?
For handhelds a lot of guys are having good luck with the Innovate LM-1. If you plan to install only in your car the Dynojet Wide Band Commander is pretty tough to beat.
hey boomer, what do you mean "If I only plan to install in my car"?
Do some sytems need a lap top vs handheld?
I am only installing in my car.
The Dynojet WBC on the other hand requires the welding of a bung into the exhaust pipe, and the installation of the WB O2 sensor just like the cars narrow band O2 sensors. Then you have to route the power lead for the WB O2, and route all those wires to where the brains of the WBC are located. The WBC also has the option of a 2 1/16 gauge for pod mounting (which I REALLY like). It's meant for installation in one car and not to be portable.
Originally Posted by 1racerdude
Horiba.... Very spendy.
It is no longer necessary to spend thousands for accuracy, but something to the tune of under $500.
Check out the wide band controller and "O2 Alert" systems from Altronics.
http://www.altronicsinc.com/
http://www.altronicsinc.com/pages/o2alert.html
"Accurate to 0.1 AFR "
Sure, and how many, that actually purchase the product, will actually compare/check it's accuracy, IN THE RANGE OF AFR GENERALLY USED. I state that because, fact is, it (sensor, theirs or any other brand) should/will read accurate in 'free air' and at stoich. That would be their disclaimer or proof that meter is accurate. Thus proves nothing, in the way of accuracy.
I suggest the Innovate LM-1. We sell the LM-1 with and without the RPM kit.Here is a link http://victoryracingengines.com/prod...hp?SECTION=224
With the data logging unit, is there no need for a a/f ratio gauge?
Or do i check a few a few runs with the handheld/datalogging unit and then if everything is ok, quit looking, or check periodically when changes are made??
If it was dyno tuned dead nuts it stays like the chip has it set so why ride around with a $4-500 guage in the car unless ya want to impress.
If ya were doing 3-4 tune up's a month it would pay to have one but ya need to have a lot of other expensive equipment to go along with it to tune and burn the chip or computer.
Does the same logic apply to vacuum and fuel pressure?
I would love to go gaugeless, all the girls would look.
Not needed.
See what the ladies say..
