BIG PROBLEM.... gass in oil and no start.. and no concert
Old 09-20-2003, 06:44 PM
  #16
PoorMan's Avatar
Didn't you say you were not getting any spark? I am getting sort of lost. Anyway, you replaced the coil and ignition module, right? I would check the coil wire with an Ohm meter. Should read near 0 resistance.
Jeff D.
PoorMan is offline
Old 09-20-2003, 06:57 PM
  #17
killerkelly95's Avatar
Re: BIG PROBLEM.... gass in oil and no start.. and no concert
Originally posted by Cory1994z28
I pulled the intake on a simple gasket replacement project on my 94 LT1....... drained the coolant.... moved the exhaust pipe to get to the drain plug... while the intake was off i noticed some gass in my lifter vally and my number 1 and 3 ports on the head were full of gass. So i put it all back together after soaking up the gass. Now the car will not start back up. i even tryed a new coil because there is no spark... this did not fix the problem... i checked for loose plugs.. i found 2 and pluged them back in...one was the O2 sensor on the driver side and one was on the throtle possition sensor. STILL!!! NO START..... ok so i checked the oil.... funny it had more than a few extra quarts in it...so i decided to drain it..... the oil was the consistancy of water and smelled like gass.. and there was a whole lot of it....i put new oil in the car and NO START...this simple project has cost me over a week... and now i have to go to the airport in the morning and i have no way to get there... and if any of you care i missed the ALmand Brothers concert because of this
Dam! I'm sorry dude thats weird cuz I have never heard of that happening before. Well I hope you can find you a ride to the airport and sorry bout the concert.
killerkelly95 is offline
gomaro
Events and Cruise Spots
05-06-2015 09:02 AM
Louey
Pacific
04-07-2015 02:10 AM
94Z28LS1toLT1
02-26-2015 07:47 AM
warmeck
02-05-2015 11:04 AM
07-04-2005 05:00 PM
Quick Reply: BIG PROBLEM.... gass in oil and no start.. and no concert
