Black connector on coil
Is it only supposed to have 1 pin on it? 95,Z28, Stock. The gray one has 2 but i pulled back that white foam piece on the black one and it doesn't look like anything is broke or does it look like anything was there. Thanks, Justin
Shoebox has the wiring diagram for the 95 dual-connector coil. It shows what is connected to the gray and the black connectors:
Look at the bottom of this page:
http://shbox.com/1/1995_pcm3.jpg
The black connector only has the pink wire attached.
carguyshu
01-22-2017 11:19 AM
Richardan15
05-30-2015 08:36 AM
