Bolt on numbers hot off the press
Old 02-24-2008, 04:53 PM
  #16
ssbowtie1's Avatar
Gaining 32rwhp from the listed mods seems a bit over realistic, but the only way to find out is to just do it and post results. If I was to make a guess, I'd say ~320rwhp. Good luck and keep us updated.
ssbowtie1 is offline
Old 02-24-2008, 05:07 PM
  #17
Jazsun's Avatar
I thought having an overly large TB hurt low end torque.
Jazsun is offline
Old 02-24-2008, 07:22 PM
  #18
Daniel6718's Avatar
guy on ls1tech said he went form stock to 58mm on a bolt on car gained no hp but 7 ft lb tq
Daniel6718 is offline
Old 02-24-2008, 08:36 PM
  #19
reamo04's Avatar
as far as throttle body, remember, you want velocity, not volume. If you have a way to have both, great, but in an otherwise stock car, your gonna have one or the other, and you want the velocity.
reamo04 is offline
Old 02-24-2008, 08:46 PM
  #20
ssbowtie1's Avatar
Will the 52mm tb even help in a bolt on application? Would love to see before/after dyno results on a stock - bolt on car.
Old 02-24-2008, 08:48 PM
  #21
Jazsun's Avatar
Yes, but was that a a bolt on LS1 or heads/cam?
Jazsun is offline
Old 02-24-2008, 09:43 PM
  #22
Daniel6718's Avatar
taht was on a bolt on lt1...not lt1...stock cam stock heads
Old 02-25-2008, 07:37 AM
  #23
BlkLT1Z28's Avatar
Originally Posted by dangalla
oh really, care to elaborate on that. i cant see one reason why more airflow would ever hurt for any reason
If this makes sense then I guess I should go and put a 1050 Dominator on my lil stock 305 in my garage.
BlkLT1Z28 is offline
Old 02-25-2008, 07:41 AM
  #24
dangalla's Avatar
that would be air and fuel, not even close. i have always been told a 58 wont help if you dont need but it wont hurt, and i would like to read otherwise
do you have any usefull information or just that stupid comment that does not even make sense
dangalla is offline
Old 02-25-2008, 08:16 AM
  #25
BlkLT1Z28's Avatar
Yes it is air and fuel......but you can adjust jets just like injector sizes. I'll put jets out of a 600dp (lets say 72's in the front, 76 in back) in the Dominator and it should be just fine, make sense? No it doesnt.
In any case then if it wont hurt, why stop at a 588mm? Put a mono blade on it.
Go look at what size TB comes on the Ram jet 502.
Im not trying to get into an argument but I tend to think about it like this, I wont replace my throttle body untill I believe it has become a limiting factor.......I dont have ~380+rwhp so why spend the $300 on it?
Old 02-25-2008, 08:17 AM
  #26
dangalla's Avatar
your going to far with this, we are only talking about putting a 58 on it
dangalla is offline
Old 02-25-2008, 08:21 AM
  #27
AHARTZ28's Avatar
do the 58mm i had done the same setup on my ex wifes car and got 7 rwhp and 12ftlbs tq. never took it off the dyno just swapped it and re-ran the car
AHARTZ28 is offline
Old 02-25-2008, 08:25 AM
  #28
BlkLT1Z28's Avatar
again, you posted this after someone said he might gain over a stocker but loose over a 52.
Old 02-25-2008, 08:30 AM
  #29
dangalla's Avatar
and i still stand by that being a load of bull, i am not saying your going to gain more over a 52 but it is not going to hurt and you sure are not going to lose power going from a 52 to a 58, and if later down the road you upgrade further you wont need to purchase a larger TB
i am sorry i was not more specific for you, i guess i just figured reading the thread you would realize that we were talking about a 58, but there always has to be that one guy....
dangalla is offline
Old 02-25-2008, 10:59 AM
  #30
Daniel6718's Avatar
Originally Posted by Z28Roxy
I think you're too hung up on the LS1 lid setup. Not to say it wouldn't be cool to do (I like custom/odd ball stuff), but as far as power gains a cold air and a ram air scoop in the fender well would probably do just as much as any other setup.
man how many times do i have to post that i did back to back runs and picked up 2 tenths in the 1/4 mile with that mod only...not to mention 1.5mph....
ls1 guys make ducts from the foglite holes to the lid and have picked up another 3 tenths and 3 mph with thtat added to it...you rock your lt1 cold air if you think that long intake with 2 bends and a crimped area by the abs block...ill do my short straight ls1 lid
why does lloyd reccomend a ls1 lid setup then?
Quick Reply: Bolt on numbers hot off the press
