brake pedal straight to the floor
the brake pedal goes right to the floor and the brake light on the dash is on, the fluid is full. the right front clapier is frozen is that the problem. im going to change that and front pads this weekend any tips. thanks
if it goes to the floor it;s not the pads.. worn out pads will extent the poistion and cause a low pedle.. not a dead peddle.
even if the fulid is full doens;t mean you do not ahve a leak, look where the master cul meets the power boster and look for mositure around the mating point. if it;s wet thats a sign of a bad master.
check all the lines and bleeders.
make sure that everything is healthy for the bads and calipers but you say one is stuck so you might have a few problems to look at
To respond to your original post....
Its Either Bad Master cylinder, a Leak, or air in your brake system.
If you havent touched anything on your brakes system (bleed brakes, ran low on fluid) then I would say its Master Cylinder or a leak. Do you have to pump your brake pedal to regain pressure? then its your Master cylinder. Does the pedal slowly go all the way down? then it may be a bad Master or a leak somewhere.
first things first.. Fix that frozen Caliper first. Check for leaks everywhere... and last replace and properly bleed the Master Cylinder. Now remember the new/remanufactured Master Cylinder has to be primed properly even before you put it on the car else you will have to do the Job twice.
Marvin
Marvin
supercharged94Z28
06-02-2015 03:32 PM
CGM2010CAMARO
04-07-2015 07:44 PM
