brakes from 94 vette
There's a guy in town who smacked his 94 vette up and is now parting some items. He has aftermarket calipers and rotors. I want to purchase them since they are much better than the stock set up. What do I need from him in order to do a complete swap? I was thinking just the rotors, calipers, pads, and mounting brackets.. anything else?
This is the same as the Baer track kit, you will need to buy brackets to make the setup work.
Also, if you have 16" Z28 wheels the 13" rotor will not fit, however I am told they fit under 16" Vette wheels, but 17" should be just about an absolute (it isn't always unless its OEM). You should be able to grab the printout from the Baer site which you can use to see if it fits under the wheel, or take your wheel and put it on the C4 and see what happens.
i have 18" rims so clearance won't be a problem but if I grab the aftermarket brackets off the vette, would'nt they work for my car?.... as for the brake lines, can i take the ones from the vette or will I have to buy new ones from someone like baer....
If there are even brackets on the Corvette they are not likely to fit the F body. If they did, it would be a common swap for us. On F bodies the caliper bolts directly to the knuckle and I'm guessing Corvettes are the same way so you will need an aftermarket bracket. I don't know about the brake lines.
You'd probably find more help in the AutoX/RR section, those are the folks that care about brakes.
