Broken Heater Hose what is this thing?
Old 01-27-2007 | 05:18 PM
2tight's Avatar
I have a broken heater hose the one that has aluminun press on fittings, What is the stuff inside that fell out? Also will it be expensive to replace?
Old 01-27-2007 | 05:30 PM
The Engineer's Avatar
LTs have "several" heater hose "sections" with the aluminum crips. Take a photo and post it so we can see which specific hose you're talking about. Or, a better discription of which heater hose section.
WD
Old 01-27-2007 | 05:31 PM
2tight's Avatar
Ok be right back
Old 01-27-2007 | 05:59 PM
2tight's Avatar
Old 01-27-2007 | 06:10 PM
ulakovic22's Avatar
Happens all the time. That plastic elbow gets brittle with the heat and snaps. I just cut the crimps off and ran a barb and hose clamps.
Old 01-27-2007 | 07:22 PM
2tight's Avatar
But what is the thing inside ?
Old 01-27-2007 | 07:40 PM
Dave89IROC's Avatar
that thing is a restricter, to slow down coolant flow through the heater core, was added to reduce noise of water flow in the core
feel free to remove it, and run a hose, you won't even notice it gone
dalynchmob
02-19-2015 07:20 PM
crazypurgatory
01-12-2015 10:45 PM
ro2207
12-04-2014 06:18 PM
pologreen97z
12-02-2014 10:42 AM
07-04-2005 05:00 PM
Quick Reply: Broken Heater Hose what is this thing?
