Buying stall converter, what RPM range does the LT4 Hot Cam operate in?
Originally posted by krispy
from what ive read id vote for a stall btw 3600-4400 if you are looking to get right into the meat of the powerband
The stock computer can handle up to 3400 stahl, then it requires reprogramming, otherwise the computer will pull horseporwer because it will assume the trans is slipping. It all depends on what your driving coditions will be, if you want to race it, or drive it around town. Good luck!
