A/C compressor not coming on?
I checked the relay its fine. I checked the compressor it isn't stuck. I used a jumper wire and it came on like that, so I have narrowed it down to the power wire that activates the relay. But, is there something else in line to the relay that could be messed up or am I gonna have to replace the entire wire?
TIA
Archie
TIA
Archie
first you need to make sure that you ahve enough freon to let the system come on. if you do.. I would check the pressure switch on the AC line. should be a 3 wire switch. unplug it and jump power from the red wire to the grey aire at the connector and see if it comes on then
Originally posted by shoebox
Also, if you have had a DTC for pressure problems, the PCM will lock out operation of the compressor. You have to reset the PCM to clear it.
just got back from work and I'm soooo tired....
