Which cam???
Old 01-14-2007, 01:13 AM
  #16
Critter's Avatar
i could tell you why. 24, engaged, student loans, car payments on her car, just bought a wedding ring, and i want 11' zr1's.
i can't afford to fix it, good thing my dd is a 1983 g-body with flowmasters lol!
Critter is offline
Old 01-14-2007, 01:42 AM
  #17
zx1216's Avatar
Doing any camswap can risk spining a bearing no matter how big the cam is. Just take your time and make sure to do a clean install. From the sounds of it a hotcam kit would work well for you, makes good power, peaks around 6k and includes the springs, 1.6 rockers and cam for about 500 bucks, do a search...
zx1216 is offline
Old 01-14-2007, 06:40 PM
  #18
VK
VK's Avatar
I agree if cost is THAT big of councern go LT4 hotcam .. I'm happy with mine, it just doesn't make much power over the stock one.
VK is offline
Old 01-15-2007, 11:42 PM
  #19
JAG05's Avatar
Can you put a CC306 in there and not do anything else but teh cam or do you need new springs or something else? also with a A4 would a CC305 or 306 be better with stock shift points?
JAG05 is offline
Old 01-16-2007, 12:22 AM
  #20
zx1216's Avatar
You have a little research to do before doing anything... the stock springs can not control a cam bigger than stock, when doing a cam swap the route mose people take are new: springs, locks/retainers, timing set, 1.6 NSA roller rockers, pushrods, guideplates and an electric waterpump... to do the job right its costly, almost $1500 for all of it. At a minimum you need new springs and locks/retainers, reusing a old timing set isn't the best idea but would work for a while. Now on to the A4 shift points, niether cam really, to get all you can out of the cams you really need to turn them higher which means higher shift points, the 305 is milder and will require a lower shift point than the cc306.
zx1216 is offline
Old 01-16-2007, 12:58 AM
  #21
JAG05's Avatar
How high are we talking with each cam?
JAG05 is offline
Old 01-16-2007, 10:56 AM
  #22
zx1216's Avatar
not really sure i guess i have a 6 speed so i can shift whenever i feal like it, haha. That being said i shift my 306 at 6800, might be a little high but it works, for a 305 not really sure, do a search, maybe 62-6400??
zx1216 is offline
rideordie
11-05-2019 04:52 PM
alex5366
02-17-2015 08:12 PM
Queens94z28
12-20-2014 09:11 PM
Queens94z28
11-20-2014 06:03 PM
Quick Reply: Which cam???
