Cam in a 94 LT-1
Cam in a 94 LT-1
Ok i got a 94 Caprice motor going in my 94 blazer and wanna do a cam also. Whcih one do you think Ill need? Its got a Granitelli MAF, Hedman headers, 2400 B&M stall(the guy at Summittalked me into it when I said i was going to get a cam), flows, 3.73 gears,LSD, and all MSD ignition.
Whats the ins and outs of the cam in this? Which one to get?What do I have to worry about? thanks for the help guys
goal for the truck are to match up to the other stuff I got and not throw codes or not work with each other. Other goals, to beat mustakes!
I was thinking the hot cam myself. Are there any other ones on the market that match the specs for cheaper? or do you know the specs and Ill match em up? Where do I get a LT1EDIT for this setup?
How about a custom grind?
Call some cam companies....(Crane/Comp) & tell them your plans. They might be able to steer you in the right direction. Then compare the cam they suggest to the Hot Cam.
Good Luck
F'n1996Z28SS
08-23-2023 11:19 PM
Sergio
01-27-2016 04:27 PM
