cam in heads on uh oh
put loyds heads on 230/236 cam nsa pro magnums tried to start car finally started ran horrible stalled, tried re starting it finally started running horrible are their any common things that i might ahve done wrong?
Check your plug wires. All the vacuum lines. Absolutely sure you had the timing chain set up right, crank and cam gears at the dots, piston at TDC, those sorts of things, if vented opti sure you had the dowel pin in the right slot.
10-31-2016 11:09 AM
oldschool
02-09-2016 09:21 PM
