cam hitting rods......
Old 11-14-2007, 09:40 PM
thebufenator's Avatar
I just installed my cam into my 383 shortblock, and the lobes are hitting the rods.......
does this mean the cam is too big?
what are my options?
I am new to this.....
thebufenator is offline
Old 11-14-2007, 09:43 PM
Stl94LT1's Avatar
You need a small base-circle camshaft to work with your rotating assembly.
Stl94LT1 is offline
Old 11-14-2007, 09:44 PM
mdacton's Avatar
what rods?
sometimes you can grind the rod a little. If not then go to the small base cam
mdacton is offline
Old 11-14-2007, 09:46 PM
I am using the stock 5.7" rods....it seems to be tapping where the rod bolt is
Old 11-14-2007, 09:47 PM
mdacton's Avatar
how much....try to grind the top of the bolt a little at a time, it may work it may not
mdacton is offline
Old 11-14-2007, 09:58 PM
1racerdude's Avatar
1racerdude is offline
Old 11-14-2007, 09:59 PM
it may only be one rod bolt.......I'll have to check.....
Old 11-14-2007, 10:06 PM
1racerdude's Avatar
They usually hit on more than one rod.
Do a Google I think 2-7 are 2 of them.
Old 11-14-2007, 10:14 PM
what exaclty is a small base circle cam?
how does it differ?
Old 11-14-2007, 10:43 PM
1racerdude's Avatar
The cam is physically smaller. This gives the rods enough room to swing.
A .900-.950 base circle should be plenty.
Old 11-14-2007, 10:45 PM
wont that effect the geometry of the valvetrain?
Old 11-14-2007, 10:56 PM
1racerdude's Avatar
NO/yes
Spects are the same on the cam, Ya will have to get longer push rods which ya probably were going to need some new ones anyway.
Old 11-14-2007, 11:43 PM
Wild1's Avatar
Silly question. Did you double check your cam timing during the install?
Wild1 is offline
Old 11-14-2007, 11:48 PM
1racerdude's Avatar
Doesent matter.
383+standard base cam = crash.
Old 11-15-2007, 07:52 AM
RicocheT's Avatar
this will work
i think it hits on 2 4 5 and 7 ... But you should check all to be sure. Doesn't take much grinding for it to clear. make sure you have about .050 clearance.
RicocheT is offline
Quick Reply: cam hitting rods......
