cam hitting rods......
Old 11-15-2007, 08:13 AM
  #16
cehan's Avatar
Originally Posted by thebufenator
I just installed my cam into my 383 shortblock, and the lobes are hitting the rods.......
does this mean the cam is too big?
You do have the timing chain set installed, right? The small base circle cam in my 383 would come in contact with the rods before I installed the timing set.
cehan is offline
Old 11-15-2007, 08:53 AM
  #17
thebufenator's Avatar
Yeah, I have the timing set installed......
Its weird, the cam is a used LE4 cam for a 383..........
maybe I need to check the timing....
thebufenator is offline
Old 11-15-2007, 08:57 AM
  #18
sleepyTA's Avatar
I have the cc306 cam(standard base circle) in my 383 with no interference problems.
sleepyTA is offline
Old 11-15-2007, 09:06 AM
  #19
Z-RATED94's Avatar
Just because it worked with someone elses rotating assembly doesn't mean it will work with the parts (rods) you have.
Z-RATED94 is offline
Old 11-15-2007, 11:51 AM
  #20
Masnart39's Avatar
1, 2, 5, & 6 will hit, and you can use a long wire tie to check clearance. They are about .060" thick
Masnart39 is offline
Old 11-15-2007, 02:05 PM
  #21
2QUIK6's Avatar
what exaclty is a small base circle cam?
how does it differ?
Here's a pic for reference, top cam is a small base circle LPE 211/219 cam.
Middle cam is a LE1.5 cam, about a 1" base circle.
Bottom cam is the stocker, about 1.2" base circle.
The idea with most cams to to make the max lift on the lobe just a tad shorter than the cam bearing surface, so the lift determines what the base circle will be.
2QUIK6 is offline
Old 11-15-2007, 03:57 PM
  #22
WS Sick's Avatar
I would just clearance the rod bolts at this point, no need to go buy a new cam, its easy and you will have no problems if you remove only whats needed.
WS Sick is offline
Old 11-15-2007, 04:10 PM
  #23
Whats the normal procedure? Just pull each of the rods out and grind with a dremel one at a time?
Old 11-15-2007, 06:26 PM
  #24
Okay, I just pulled the cam and its "base" is exactly 1"
I know 7/8 is hitting, but cant figure out which one.
and then it looks like 1/2 is, not sure which.
Old 11-15-2007, 06:28 PM
  #25
mdacton's Avatar
put some clay on it.....put a little oil on top of the clay so it wont stick on the cam, rotate it and see whats hitting.
What rod bolts are you using?
mdacton is offline
Old 11-15-2007, 07:04 PM
  #26
okay, need to get clay......
I am using ARP rod bolts
is there anything else I need to do other then remove the rod and grind the head of the bolt?
any changes after re-installing the rod?
Old 11-15-2007, 07:06 PM
  #27
mdacton's Avatar
you have to make sure it will even work first. Just do a little at a time and try it at least. Take the rings off so you don't break one...you will have it in and out several times
mdacton is offline
10-31-2016 11:09 AM
NewsBot
03-13-2015 07:15 AM
armedtrigger
02-24-2015 08:30 PM
mark0006
02-03-2015 05:12 PM
Smokn '94 Z
08-04-2002 06:11 PM
Quick Reply: cam hitting rods......
