Cam install now nasty miss
#33
Originally posted by OffspringZ28
the extent of my fbody knowledge is installing headers, past that i dont know whats going on. picked up a few tips from the installer but i still wouldnt attempt it. (cam)
#35
have you reseated the opti yet? i'm betting on the opti still giving you problems even after you get everything hooked up. when i installed a new opti the new one took forever to slide on perfectly flush. i had to reseat it several times and when i got it right it just slid right on no problems. i know it's going to be a pain in the a$$ but why risk it failing down the road because of an improper install?
#36
ok well, the car def runs better but still misses. although sometimes (esp. in the colder weather we've had recently) it runs 100% and screams at wot. which is why i dont think it is the opti at all. maybe i have bad plugs? because of an 02 hiccup i unplugged one of the 02's from its extender to go into "limp home mode" in which the car ran fine, just not the best gas mileage. been like this for a couple months. because the car is a daily and im a full time student i dont really have time to diagnose problems as much as id like to. i just dont get it, in the cold weather it seems to run fine, albeit still stumble now and then (at night, early morning etc).
#37
#39
basically sometimes it runs fine and sometimes it misses or rather, stutters. seems to be running a lot better than when i first posted this though. do i just need a tune? am i feeling cam surge?
#41
well the i reset the computer and it runs BETTER but its not there yet. once again sometimes it will run fine, good enough to the point where i can even floor it in 6th and it wont buck or anything. then other times it will seem to miss all through the rpm range. this is very trying. i feel like i am so close.
#44
having similar problem, mine begins to miss about high 3 to 4K and all the way up (w/ cc306) runs better when cool but still not what it should be by any means, brand new opti, people i talk to think it's running lean up top....i still have STOCK injectors, imean original ones...and i am hoping that some 30#s and regulator may cure it...any suggestions
#45
i doubt your (our) problem is related to fuel. both cams we have are still driveable with the stock tune. what i feel is an actual miss, the seems to stutter and then if i let off the throttle a little it will smooth out. i am waiting on my AKM cable to get here so i can drive the car around and see what exactly is acting up. Free scan should be sufficient. I just dont know what to look for. I guess if all the sensors check out ok then it is prolly the opti or a burned wire? I dont think its either of those though because of the way the car will run fine for a couple of minutes then get squirley again.
