Cam installed now ticking
Old 09-30-2011 | 12:58 AM
  #16
97WS6SCharged's Avatar
Re: Cam installed now ticking
You might want to redo the procedure and check the length of the tool with a set of calipers. I'm not trying to cast doubt on you or your mechanic but stock pushrods are what that application should use.
Old 09-30-2011 | 09:41 AM
  #17
97 CAIVIAROSS's Avatar
Chris
Won't that just change where the rocker tip rides on the valve stem end?
Derek
Old 10-01-2011 | 01:15 AM
  #18
It will change the geometry a little bit. Have you checked the rockers lately to see if they have any marks from contacting the top side of the valve face? Since you haven't cut the heads, changed gaskets and are unlikely to be using a small base cam (would require taller lifters) the stock length pushrods would be a better bet as far as length goes.
If you can find a solid roller lifter to use with the pushrod length checker that would be more ideal than using a hydraulic roller lifter even with the plunger welded.
Old 10-02-2011 | 05:16 PM
  #19
I will pull the rockers on that side to see if there are any marks.
Old 10-02-2011 | 05:49 PM
  #20
Kevin Blown 95 TA's Avatar
I had a ticking problem once near the back of the driver's side and it was driving me crazy. Anyhow, after much fuss and wasted effort, it turned out to be a header leak - not at the gasket, but in the tube to flange weld. I took the header off and found a pin hole leak that was making the noise - spot welded that **** back up and noise was gone.
importkiller94
01-17-2015 10:03 PM
Queens94z28
12-20-2014 10:11 PM
Noenav
12-06-2014 08:35 PM
F(ast)-body
02-26-2003 10:05 AM
GigaMp3z
02-20-2003 03:57 PM
