Which cam for my 355 nitrous set-up?
I have been trying to figure out which cam I should use to spray 150-200 shot of nitrous, but have found the hotcam, cc306, and the GM847 wasn't good for nitrous due to a low lsa. I was thinking of choosing one of these from this website that had 114-115 lsa, but would they even be close to the ones I mentioned above when I'm just on n/a. Here is the website and again the ones I am looking at are the ones with 114 and 115 lsa. http://www.cmotorsports.com/engine/l...ft-design.html
Also if I do get one of these cams how do I know what springs, rocker arms, pushrods etc. to get or do I just call them to figure that out. Thanks for any help.
Re: Which cam for my 355 nitrous set-up?
If you go to 114-115 you will compromise NA power, the 112 cams should work acceptably and retain NA powerthe ones you were looking at would make decent choices too the 306 in particulat has a wide duration split with a lot more on the exhaust side which is something you want in a juice cam with the motor.
The 112 LSA are already a bow to the fuel injection carbed motors often use more like 106-8 so in the grand scheme 112 is already fairly wide.
