Cam positioning and Optispark?
I'm just curious as to what could have caused my first 3 opti's to destroy themselves internaly. I'm running the delteq system now and everything runs fine for the most part accept for random misses at times. Cam dowl pin length is fine.
Here's what I am thinking could be causing it.
112 LSA installed on a 109 centerline instead of the recommended 108 thus 3 degrees advanced.
So question is could the cam being set up like this cause the opti to be out of position for the spark events?
Just some random data that may or may not influence your response:
DCR 8.4
SCR 11.3
Heads milled 50cc's
1995 OBDI
I was thinking of eventually picking up a dynaspark but if the cam is degreed weird then a better opti realy isn't going to help any. Maybee the cam position has nothing to do with it I don't know. That's why I'm asking. Thanks!
DCR 8.4
SCR 11.3
Heads milled 50cc's
1995 OBDI
Copied from "shoebox" site.
GM specs indicate that the dowel should be .620" long (protrusion from the front face of the cam) for the vented optispark. Some people have said it is supposed to be .685". Mine was actually .650" and still was in no danger of bottoming out in the optispark drive (I'm thinking .685" might be the max it could be).
