cam question
cam question
I got a friend who is going to give me a cam for my 96 z28 and i was wondering how radical it is. He said it is a comp cam with 224/230 114 LSA . How does that compare to the cc306 or cc305? thanks
Well if he does not come through i was thinking about the cc305 with 1.6 rockers or the cc306 with 1.5 rockers...what type of numbers would the cc305 and 1.6 rockers be? thanks for all the help guys...as you can tell, i don't know alot about cam numbers
If you're going to get a 305, you can save a little money and just get the Hotcam. They put out nearly identical power numbers. With either of these cams and tuning, you can gain 40-50 more hp at the wheels.
The 305 or Hotcam is not even in the same league as the 306. The 306 will perform MUCH better with ported heads. And if you're stuck with emissions, don't plan on passing with the 306 either. The 306 is made to rev.
oldschool
02-09-2016 09:21 PM
Brandon Wittmer
12-20-2014 09:51 PM
